dbreg
#1 Posted : Thursday, January 3, 2008 11:27:23 PM(UTC)
dbreg
My dryer has been working great for the last 14 years and just today I noticed that it was not drying. After opening the lower panel I observed that the gas burner is igniting, but for a short duration no matter what heat setting. Is there an adjustment and or a cleaning procedure that I should try or do I need to replace that gas burner/igniter unit? Everything else has been working great. Thanks in advance for your help.
#2 Posted : Friday, January 4, 2008 1:24:26 PM(UTC)
Most likely the problem caused by the clogged vents and restricted air flow.
- Here are the break down diagrams for the Whirlpool dryer Model LGV7646AW0
Good luck.
