Micro is not heating Fuse is good and touch pad executes commands. I tested the micro switches- all appear to be working. I tested the capacitor and it reads 1uF. Not sure if the diode affects operation of unit. I cannot get continuity accross it in either direction nor do I get a reading using a diode tester.
mmmmmmmmmm Originally Posted by: villano ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Micro is not heating Fuse is good and touch pad executes commands. I tested the micro switches- all appear to be working. I tested the capacitor and it reads 1uF. Not sure if the diode affects operation of unit. I cannot get continuity accross it in either direction nor do I get a reading using a diode tester.
:confused: Originally Posted by: villano ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Micro is not heating Fuse is good and touch pad executes commands. I tested the micro switches- all appear to be working. I tested the capacitor and it reads 1uF. Not sure if the diode affects operation of unit. I cannot get continuity accross it in either direction nor do I get a reading using a diode tester.
