GaydosBlessed
#1 Posted : Thursday, June 25, 2009 5:38:02 AM(UTC)
GaydosBlessed
No power at all - worked for one load died on the next.
Looking to replace the hi temp thermal fuse but not sure if that will solve the problem. I need my dryer back.:confused:
#2 Posted : Thursday, June 25, 2009 5:51:48 AM(UTC)
Replacement parts for FRG LEQ2152ES0 | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/p...ebster/134509400efsa.pdf
Two ways to check it:
The Pro's Method
Unplug the unit.
Remove one wire from the fuse.
Measure it with a meter.
Should be 0 ohms.
The Jiggery Pokery Method
Unplug the unit.
Remove both wires from the fuse and short them together.
Tape them up so they cannot short to the frame etc.
Plug it in and give it a try.
If it is blown replace it ASAP as it is a critical safety device.
Give the interior including the blower wheel a good cleaning.
Also clean and check your vent system.
These are the most common causes of it blowing.
GaydosBlessed
#3 Posted : Friday, June 26, 2009 11:55:04 AM(UTC)
GaydosBlessed
I have the part now how do I replace it?
#4 Posted : Saturday, June 27, 2009 4:05:56 AM(UTC)
See the following
http://www.applianceaid.com/ww-and-mc.html
Would also be a good idea to clean and check the rear drum bearing.
Re-grease it with high temp grease.
Also check the belt etc.
Frigidaire Electric Dryer - All Lights Are Flashing (Dryer Repair)
by Guest 4/15/2021 8:50:11 AM(UTC)
Frigidaire electric dryer (Dryer Repair)
by n.mcphee 6/14/2018 6:55:43 AM(UTC)
Frigidaire electric dryer stop advancing (Dryer Repair)
by blueking 9/13/2014 4:38:26 PM(UTC)
Frigidaire Electric Dryer (Dryer Repair)
by Menotu 6/2/2014 4:28:45 AM(UTC)
Frigidaire electric dryer, no heat (Dryer Repair)
by stevedill 4/15/2013 4:01:56 PM(UTC)
Frigidaire electric dryer belt replacement (Dryer Repair)
by award 6/21/2010 11:14:23 AM(UTC)
Frigidaire Electric Dryer - Blinking Lights (Dryer Repair)
by gin4sing 1/4/2010 10:32:04 AM(UTC)
by cafero99 5/24/2009 4:00:11 PM(UTC)
Need help replacing heating element coil in Frigidaire electric dryer (Dryer Repair)
by JeffJ 4/27/2009 4:22:44 AM(UTC)
Frigidaire Electric Dryer Not Heating (Dryer Repair)
by tleelee 1/22/2009 7:13:52 AM(UTC)
Frigidaire Electric dryer Hums and timer clicks (Dryer Repair)
by ButchL 1/18/2009 11:34:16 AM(UTC)
frigidaire electric dryer (Dryer Repair)
by atlanta handyman 11/20/2008 2:20:38 PM(UTC)
by outlaw 1/19/2008 5:43:16 AM(UTC)
