No power at all - worked for one load died on the next.
Looking to replace the hi temp thermal fuse but not sure if that will solve the problem. I need my dryer back.:confused:
Here are your parts Replacement parts for FRG LEQ2152ES0 | AppliancePartsPros.comHere is the tech sheet http://manuals.frigidaire.com/p...ebster/134509400efsa.pdfTwo ways to check it: The Pro's Method Unplug the unit. Remove one wire from the fuse. Measure it with a meter. Should be 0 ohms. The Jiggery Pokery Method Unplug the unit. Remove both wires from the fuse and short them together. Tape them up so they cannot short to the frame etc. Plug it in and give it a try. If it is blown replace it ASAP as it is a critical safety device. Give the interior including the blower wheel a good cleaning. Also clean and check your vent system. These are the most common causes of it blowing. |
THIS FORUM IS DEAD!!!!!!! |
I have the part now how do I replace it?
