The motor is running on the dehumidifier but it does not pick up the moisture. The pan that contains the water is empty, no water. I know that it is an old dehumidifier, but is there something that can correct this problem. Thank you
Originally Posted by: plches The motor is running on the dehumidifier but it does not pick up the moisture. The pan that contains the water is empty, no water. I know that it is an old dehumidifier, but is there something that can correct this problem. Thank you the motor runs on my dehumidifier but it does not pick up any moisture. the pan that collects the water is dry and empty. Can this problem be taken care of without having to buy an new dehumidifier. Thank you
:mad: Originally Posted by: plches the motor runs on my dehumidifier but it does not pick up any moisture. the pan that collects the water is dry and empty. Can this problem be taken care of without having to buy a new dehumidifier. I know this is an old Magic chef model, but I cannot afford an new defumidifier right now.
Goldstar Dehumidifier Compressor Won't Run
(Heating, Ventilation, and Air Conditioning (HVAC))
by gregger77
8/22/2014 5:13:10 PM(UTC)
frigidaire dehumidifier
by billwhoisjolly
4/24/2014 8:41:31 AM(UTC)
LG Dehumidifier
by buckeyemick
8/9/2012 8:15:07 AM(UTC)
DeLonghi dehumidifier - no water
by cflick
6/19/2012 7:13:54 AM(UTC)
DEHumidifier
by Tylercoady
5/29/2012 2:37:36 PM(UTC)
dehumidifier code
by tinag
1/16/2012 12:00:41 PM(UTC)
Dehumidifier Problem
(Dishwasher Repair)
by montihouse
8/26/2011 11:20:09 AM(UTC)
Need to ghetto fix a dehumidifier
by Matt40
7/21/2011 11:50:47 AM(UTC)
dehumidifier
by bill2164
7/8/2011 7:08:44 AM(UTC)
Dehumidifier only runs a few minutes
by ween99
5/23/2011 4:45:19 AM(UTC)
Dehumidifier Compressor Clicks On & Off
by mmichaelk
8/25/2010 1:23:29 PM(UTC)
Dehumidifier trips
by shizihua
8/21/2010 11:29:22 AM(UTC)
Dehumidifier
by JDG58
9/11/2009 11:40:31 AM(UTC)
Dehumidifier compressor not turning on...
by Seanyboy
8/21/2009 8:10:56 AM(UTC)
Sears Dehumidifier
by halpink
8/16/2009 10:50:23 AM(UTC)
