ween99
#1 Posted : Monday, May 23, 2011 4:45:19 AM(UTC)
ween99
If I take out the water bin and push the inside red button and hold it the dehumidifier will run. When I replace the bin it runs for a few minutes then shuts off and does not come back on. There is no sign of water but it's only running for a short time.
I've cleaned the filter but not sure what else to check.
nollrsv3
#2 Posted : Monday, June 6, 2011 9:48:20 AM(UTC)
nollrsv3
check teh float switch to be sure that it is operating correctly and unobstructed
nollrsv3
#3 Posted : Monday, June 6, 2011 9:49:38 AM(UTC)
nollrsv3
:cool: check teh float switch to be sure that it is operating correctly and unobstructed
