chaionsaw
#1 Posted : Friday, December 21, 2007 9:59:15 AM(UTC)
chaionsaw
I have no heat . I want to chexk the fuse but I cant seem to get the bottom cover off. It seems like it is springed to some thing. No clicking noise at all like the heat is not even starting..
#2 Posted : Friday, December 21, 2007 12:14:36 PM(UTC)
The first thing I would check is the thermal fuse (#59 on the bulkhead parts break down diagram).
In order to remove the bottom panel you have to push in (using a putty knife) the retainer (#46 on the cabinet break down diagram) on each side on top of the bottom panel.
Replace the thermal fuse if it's open.
According to the manufacturer instructions, if the thermal fuse is open, the cycling thermostat has to be replaced either (#42 on the bulkhead parts break down diagram).
If there is nothing wrong with the thermal fuse, then check the igniter (#4 on the burner break down diagram).
- The part number for the thermal fuse is AP3133489
- The part number for the cycling thermostat is AP3131939
- The part number for the igniter AP3094138
Good luck.
chaionsaw
#3 Posted : Saturday, December 22, 2007 1:20:14 PM(UTC)
chaionsaw
Thank You that is what it was fuse.. thank you very much and have a great christmas...
#4 Posted : Saturday, December 22, 2007 1:37:26 PM(UTC)
I'm glad you were able to fix it.
Merry Christmas and Happy New year!
another no heat dryer question (Dryer Repair)
by davidlswenson 12/30/2014 9:43:21 AM(UTC)
Confusing troubleshooting on no heat dryer (Dryer Repair)
by bmpmsnow 5/18/2011 8:30:34 AM(UTC)
NO heat DRYER (Dryer Repair)
by diamondr 11/22/2009 5:12:49 AM(UTC)
No Heat Dryer Problem (Dryer Repair)
by SpeedyG 10/28/2008 5:02:39 PM(UTC)
My no heat dryer puzzle for you wizards. (Dryer Repair)
by jfull1965 10/22/2008 2:28:54 PM(UTC)
