SpeedyG
#1 Posted : Tuesday, October 28, 2008 5:02:39 PM(UTC)
SpeedyG
Everything works fine but I get no heat. the igniter lights OK but the gas does not ignite:confused:
#2 Posted : Wednesday, October 29, 2008 4:22:07 PM(UTC)
Most likely the problem is a bad coils on the gas valve.
- The part number for the coil kit is AP79737
Here are the break down diagrams for the Speed Queen dryer Model HG6009
eyefish
#3 Posted : Sunday, August 30, 2009 12:13:03 PM(UTC)
eyefish
Hi Gene,
I have this same problem, same dryer (model HG6009W) however.....the gas ignites into a flame only when the dryer is cold.
When you start it up; everything works fine, for about a minute, then the flame shuts off, & the gas valve will no longer supply gas for it to re-ignite.
The igniter heats up to bright white hot, but no gas to lite up. (until you let the dryer sit a few hrs to cool off)
I tried jumping the t-stat, (@ 2 o'clock of 3" flame tube) but that didn't help.
I DIDN'T try jumping the flame sensor AP2910747 (should I?)
Or is it definitely the Coil Kit AP79737 (that you suggest in the 10 mo old reply above)
You've been a huge help to me in the past on a Microwave (I'm the Volvo Technician)
I hope you can help me this time.
The coil kit is expensive, & I wouldn't want to buy it unless it was defilitely the offending part.
Any way to test it with checking resistance?
Thanks,
Al
leithouse
#4 Posted : Saturday, February 20, 2010 9:43:11 PM(UTC)
leithouse
If the gas is on and the ignitor glows but it doesn't light, replace the coils on the gas valve. p/n:279834 universal # about $15.
eyefish
#5 Posted : Sunday, February 21, 2010 4:52:54 AM(UTC)
eyefish
Thanks Leithouse.
Yes, it was the coils.
I repaired it in August, shortly after I posted.
I bought a OEM coil kit, which I got for a pretty good price (I think it was about $42).
So I didn't know which individual coil was bad.
But later, I took apart the old coil kit, & individually tested the resistance of each coil & found one to be bad, & the others fine.
I now know to test them individually in the future & would be able to replace the offending coil, for about $12 or less.
Al
