In-door water dispenser will not dispense water.
Water leaks from the bottom of the refrigerator when you activate the dispenser button.
I can hear the normal sound the dispenser makes when it dispenses water.
Thanks - Gord
If you have a water filter, it may need replaced. If not look behind the crisper at the water reservoir to see if it's leaking there and dripping down.
I did replace the filter but it did not help.
A few more questions - If a line or tank was frozen would there be water leaked onto the floor after attempting to get the dispenser to work?
If the problem is a solenoid would I hear the "pump" being operational when I attempt to use it? Or would it be silent?
Thanks for your help.
Water Supply Line had come loose.
