clubbber333
#1 Posted : Monday, May 25, 2009 8:29:02 AM(UTC)
clubbber333
In-door water dispenser will not dispense water.
Water leaks from the bottom of the refrigerator when you activate the dispenser button.
I can hear the normal sound the dispenser makes when it dispenses water.
Thanks - Gord
woodchuckie
#2 Posted : Monday, May 25, 2009 11:53:39 AM(UTC)
woodchuckie
If you have a water filter, it may need replaced. If not look behind the crisper at the water reservoir to see if it's leaking there and dripping down.
clubbber333
#3 Posted : Monday, May 25, 2009 1:22:10 PM(UTC)
clubbber333
I did replace the filter but it did not help.
A few more questions - If a line or tank was frozen would there be water leaked onto the floor after attempting to get the dispenser to work?
If the problem is a solenoid would I hear the "pump" being operational when I attempt to use it? Or would it be silent?
Thanks for your help.
clubbber333
#4 Posted : Monday, May 25, 2009 2:37:24 PM(UTC)
clubbber333
Water Supply Line had come loose.
