Zanesmom310
#1 Posted : Tuesday, November 8, 2011 12:27:22 PM(UTC)
Zanesmom310
Hi my mother in law has a Tappan gas range that says F31 in the digital read out and the oven wont work now could you please help and tell me what that code means cause we cant find out anywhere.
Thanks Stephanie
#2 Posted : Tuesday, November 8, 2011 3:34:39 PM(UTC)
Stephanie,
The "F31" error code means "oven temperature probe (aka a sensor) shorted". This probe has to be checked for continuity. The normal resistance reading at the room temperature should be about 1100 Ohms.
The range has to be pulled out of the wall and the rear panel has to be removed to access the plugs and wires.
If the reading is wrong, replace the probe.
If the reading is correct, check the wires between the probe and the control board, including all plugs.
If there is nothing wrong, replace the control board (aka a clock). It is recommended by the manufacturer to replace the overlay together with clock because it is glued on.
- The probe/sensor Part number: AP4433173
- The control board Part number: AP3959387
- The overlay Part number: AP2126493
Kenmore elite oven error code F31 and F5 (Oven Repair (including Ranges and Cooktops))
by defcon4 1/31/2010 7:58:03 PM(UTC)
Error Code F31 (Oven Repair (including Ranges and Cooktops))
by richcanfixit 1/27/2009 7:50:45 AM(UTC)
