2 Pages<12
twotyer
#11 Posted : 16 years ago
twotyer
Yes unit was working, I had to replace the pump/motor assembly because it was leaking. The problem occured after that. I will look for the wiring diagram.
#12 Posted : 16 years ago
Was there any wiring that you could have messed up when reconnecting the unit or was it all one way plugs?
Also I might try disconnecting the unit from ground (green wire) just as a test. It may give a clue to what is going on.
richappy
#13 Posted : 16 years ago
richappy
Hard to do, check to see if you swapped the motor connector with the solenoid connector.
2 Pages<12
