RON SCHINHARL
#1 Posted : Friday, November 4, 2011 6:47:39 AM(UTC)
RON SCHINHARL
Oven Will Not Heat Up. Set To Bake And Control Head Just Clicks. Burner Works, Change Oven Temp. Sensor And Clock But No Change. Set To Clean Just To See If It Will Heat Up And It Did Fine. Can Someone Help?
Joe / APP Team
#2 Posted : Friday, November 4, 2011 8:35:38 AM(UTC)
Joe / APP Team
Ron,
In the clean cycle, both the Bake and Broil elements are activated and producing heat, thats probably why the range got hot in the clean cycle(only).
Have you programmed and check a Broil cycle for operation and heat ?
You didn't mention any fail codes in the display, so I'm thinking you need to remove the racks and bottom panel from the oven and check the bake element for wiring and or damage. If you have a multimeter check for 240 VAC across the element terminals when you program the bake cycle and temperature.
Part number: AP4701262
If you have the voltage at the element terminals, you'd have a damaged element, no voltage would indicate a damaged supply wire or inoperative relay on the control board.
RON SCHINHARL
#3 Posted : Saturday, November 5, 2011 7:52:46 AM(UTC)
RON SCHINHARL
Thanks For Your Help. The Lower Element Does Not Heat Up.i Will Have To Find A Multimeter Thw Element. Thank You For Your Help.
Joe / APP Team
#4 Posted : Tuesday, November 8, 2011 6:05:28 AM(UTC)
Joe / APP Team
Ron,
Great job,
A meter will usually save you some money in the long run. and will come in handy for other projects.
Part number: AP3873826
You'll do fine, once you have the meter.
GE Cafe Oven help. (General Talk)
by contay 8/19/2019 8:32:40 AM(UTC)
Thermador oven help (Oven Repair (including Ranges and Cooktops))
by Lepetitmatin 8/16/2019 6:08:48 PM(UTC)
Kitchenaid Oven Help (Oven Repair (including Ranges and Cooktops))
by ehenry 12/9/2015 3:59:14 PM(UTC)
Thermador Professional Oven Help Needed!! (Oven Repair (including Ranges and Cooktops))
by fastguy1955 1/27/2015 6:20:43 PM(UTC)
Fridgidaire electric oven help (Oven Repair (including Ranges and Cooktops))
by ahardb0dy 7/28/2014 4:31:08 PM(UTC)
need oven help (Oven Repair (including Ranges and Cooktops))
by brett cook 3/18/2014 5:16:43 PM(UTC)
Whirlpool oven help (Oven Repair (including Ranges and Cooktops))
by dendsley 9/15/2011 3:43:49 AM(UTC)
Frigidare oven Help (Oven Repair (including Ranges and Cooktops))
by purple75 3/6/2011 11:00:35 AM(UTC)
Gas oven help (Oven Repair (including Ranges and Cooktops))
by sammy378 7/2/2010 6:27:04 PM(UTC)
Preway oven Help (Oven Repair (including Ranges and Cooktops))
by apache23 3/4/2010 7:35:35 AM(UTC)
Tappan Oven help (Oven Repair (including Ranges and Cooktops))
by Blackhawk141 12/15/2008 1:13:25 PM(UTC)
Oven Help! (Oven Repair (including Ranges and Cooktops))
by nedwards 12/15/2008 1:05:17 PM(UTC)
admiral oven help (Oven Repair (including Ranges and Cooktops))
by Corey Elliott 11/5/2008 1:14:20 PM(UTC)
Oven help please! (Oven Repair (including Ranges and Cooktops))
by cndybkr 10/20/2008 6:19:13 AM(UTC)
by buffcr39 8/26/2008 7:17:44 AM(UTC)
