buffcr39
#1 Posted : Tuesday, August 26, 2008 7:17:44 AM(UTC)
buffcr39
have dacor wall oven with faulty electronis. The light comes on and off by itself, then I couldn't set the clock although it displays, now in the middle of broil cycle it quit heating and won't heat on bake also but the convection fan comes on. Is this a faulty control panel or is there some kind of relay board that might cause this or something else?
#2 Posted : Tuesday, August 26, 2008 8:17:30 PM(UTC)
Open the control panel and locate the thermal cut-off switch (next to the latch assembly).
The thermal cut-off switch
UserPostedImage
This switch is resettable. You can reset it by pushing in the red button in the middle. Check this switch for continuity after reset it. Replace the switch if it's still open.
Also the control board most likely is bad and has to be replaced.
Restore the power to the oven and check bake and broil. Post the results.
- The part number for the thermal cut-off switch is AP3391739
- The part number for the control board is AP3390990
mikembs
#3 Posted : Monday, January 26, 2009 2:39:36 PM(UTC)
mikembs
i found this thread and it wa the reset switch on my model dacor 2200d oven. thanks so much for being here you saved me at least $200.00
GE Cafe Oven help. (General Talk)
by contay 8/19/2019 8:32:40 AM(UTC)
Thermador oven help (Oven Repair (including Ranges and Cooktops))
by Lepetitmatin 8/16/2019 6:08:48 PM(UTC)
Kitchenaid Oven Help (Oven Repair (including Ranges and Cooktops))
by ehenry 12/9/2015 3:59:14 PM(UTC)
Thermador Professional Oven Help Needed!! (Oven Repair (including Ranges and Cooktops))
by fastguy1955 1/27/2015 6:20:43 PM(UTC)
Fridgidaire electric oven help (Oven Repair (including Ranges and Cooktops))
by ahardb0dy 7/28/2014 4:31:08 PM(UTC)
need oven help (Oven Repair (including Ranges and Cooktops))
by brett cook 3/18/2014 5:16:43 PM(UTC)
by RON SCHINHARL 11/4/2011 6:47:39 AM(UTC)
Whirlpool oven help (Oven Repair (including Ranges and Cooktops))
by dendsley 9/15/2011 3:43:49 AM(UTC)
Frigidare oven Help (Oven Repair (including Ranges and Cooktops))
by purple75 3/6/2011 11:00:35 AM(UTC)
Gas oven help (Oven Repair (including Ranges and Cooktops))
by sammy378 7/2/2010 6:27:04 PM(UTC)
Preway oven Help (Oven Repair (including Ranges and Cooktops))
by apache23 3/4/2010 7:35:35 AM(UTC)
Tappan Oven help (Oven Repair (including Ranges and Cooktops))
by Blackhawk141 12/15/2008 1:13:25 PM(UTC)
Oven Help! (Oven Repair (including Ranges and Cooktops))
by nedwards 12/15/2008 1:05:17 PM(UTC)
admiral oven help (Oven Repair (including Ranges and Cooktops))
by Corey Elliott 11/5/2008 1:14:20 PM(UTC)
Oven help please! (Oven Repair (including Ranges and Cooktops))
by cndybkr 10/20/2008 6:19:13 AM(UTC)
