Replacement parts for WHIRLPOOL LE5700XPW0 Residential Dryer | AppliancePartsPros.comSee the attachment for a wiring diagram. I could not find one for a XPW0 so it is for a XSW1. Hopefully it will be the same or close to your unit.
Also I am assuming this is a USA model as there is a European model also available.
My dryer stopped heating so I replaced the heating element, High limiter thermostat, thermal fuse and the thermostat to make sure I covered all the bases. However, after everything was replaced I still have not heat. I checked the fuse box to see if the 220 was not tripped and the continuity of the parts to make sure everything was functional. What am I missing
By the sound of it you do not have a meter.
You cannot tell if you have the 240 just by looking at the breaker, sometimes you can loose half the line without tripping the breaker and the heating coil requires the full 240 volts.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
Be careful as 240 volts is lethal !!!If the power is good.
Unplug the unit and set the timer to mid-cycle timed dry with high heat.
Set your meter to a low scale (usually 200 ohms)
Attach /tape one meter lead to L1 at the line cord and leave it there.
Now work your way back through the unit part by part till you find the open circuit.
