I've cleaned the duct work and still no heat. The thermal fuse seems to be located in front of the duct...how do you get to it to replace or to put a meter on it. If the heating element needs to be replaced, which panel do you take apart, top, back, they seem to be spot welded... thanks for your help!
please reply as soon as possible
Go to: http://www3.sears.com/Input your model number. Then select "DRY/CAB HEATER" It would appear that you will have to remove the drum to access the element. I believe that you have a broken element. Thank You
FIRST check to see if you have the right voltage going to the dryer,There should be 240 volt,s going to the dryer.
