racefan
#1 Posted : Thursday, December 6, 2007 7:12:47 PM(UTC)
racefan
I've cleaned the duct work and still no heat. The thermal fuse seems to be located in front of the duct...how do you get to it to replace or to put a meter on it. If the heating element needs to be replaced, which panel do you take apart, top, back, they seem to be spot welded... thanks for your help!
racefan
#2 Posted : Friday, December 7, 2007 7:16:23 AM(UTC)
racefan
please reply as soon as possible
Bigboss88
#3 Posted: : Friday, December 7, 2007 7:40:04 AM(UTC)
Bigboss88
Go to: http://www3.sears.com/
Input your model number. Then select "DRY/CAB HEATER"
It would appear that you will have to remove the drum to access the element.
I believe that you have a broken element.
Thank You
abbie
#4 Posted : Friday, December 7, 2007 10:55:29 AM(UTC)
abbie
FIRST check to see if you have the right voltage going to the dryer,There should be 240 volt,s going to the dryer.
Dryer tests good but stil no heat!!! (Dryer Repair)
by Aaron Chesler 8/26/2016 5:34:03 AM(UTC)
No heat!!! (Dryer Repair)
by tdetwiler 1/9/2015 8:00:20 PM(UTC)
Power & continuity but no Heat!! (Oven Repair (including Ranges and Cooktops))
by stockgoblin 1/21/2013 5:31:33 AM(UTC)
New Parts and still no Heat!!!! (Dryer Repair)
by larosa00 10/29/2011 5:37:59 PM(UTC)
No HEAT!!! (Dryer Repair)
by Charley Albert 1/4/2011 11:53:50 AM(UTC)
No heat!!! Please help! (Dryer Repair)
by importtek 11/3/2010 3:30:40 PM(UTC)
i have no heat!!! (Oven Repair (including Ranges and Cooktops))
by timwalls 5/13/2010 10:20:09 AM(UTC)
