I have a Kenmore Elite Dryer (Model# 110.73952102). I recently replaced the electronic panel after one of the resistors was fried and switched the heat relay with the motor relay. Now everything else works except the fact that there is no heat. I also opened the kick plate to clean a little bit and found a loose red/yellow wire that originates from the moisture sensor @ the electonic panel. I donot know if it should be left like that, or be attached to something?
Why did you switch the motor relay with the heater relay? The red/yellow wire from the moister sensor should be connected to the P2-4 terminal on the control board. Regarding the heat problem, you have to check the heater strip circuit and perform all tests in accordance with the technical documentations. Gene.
