sdemiss
#1 Posted : Saturday, December 1, 2007 8:07:41 PM(UTC)
sdemiss
I have a Kenmore Elite Dryer (Model# 110.73952102). I recently replaced the electronic panel after one of the resistors was fried and switched the heat relay with the motor relay. Now everything else works except the fact that there is no heat. I also opened the kick plate to clean a little bit and found a loose red/yellow wire that originates from the moisture sensor @ the electonic panel. I donot know if it should be left like that, or be attached to something?
#2 Posted : Sunday, December 2, 2007 7:47:40 PM(UTC)
Why did you switch the motor relay with the heater relay?
The red/yellow wire from the moister sensor should be connected to the P2-4 terminal on the control board.
Regarding the heat problem, you have to check the heater strip circuit and perform all tests in accordance with the technical documentations.
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
