GeorgiaV
#1 Posted : Tuesday, November 27, 2007 7:08:58 AM(UTC)
GeorgiaV
My dryer was working fine yesterday, but today I put a load in and pushed the button it wouldn't start and the light went out. I still hear the timer. I checked the breakers, no problem there. Please help.
#2 Posted : Tuesday, November 27, 2007 9:04:28 AM(UTC)
The first thing I would check is the connection of the power cord to the dryer for burned wires.
GeorgiaV
#3 Posted : Tuesday, November 27, 2007 10:41:47 AM(UTC)
GeorgiaV
Checked the wires from the dryer and at the wall, looks good.
abbie
#4 Posted : Tuesday, November 27, 2007 11:18:32 AM(UTC)
abbie
i don,t know how old this dryer is, but I would check the door switch and lever behind the door,make sure it makes a clicking sound . Then check [if it,s a old dryer]the belt, if the belt breakes the idler pulley drops down an hit,s a belt kill switch, this will stop the motor. Try that after you check the voltage.
GeorgiaV
#5 Posted : Tuesday, November 27, 2007 4:11:27 PM(UTC)
GeorgiaV
It is a very old dryer. Voltage checks out and it is getting electricity to dryer. The switch behind the door does not make a clicking sound. I pulled the top off to check the switch behind the door and it is getting electricity to it. The belt appears intact. I did not feel any tears, areas of wear or nicks.
abbie
#6 Posted : Wednesday, November 28, 2007 11:04:46 AM(UTC)
abbie
check to see if the door switch has continuity. It should click.
#7 Posted : Wednesday, November 28, 2007 5:28:32 PM(UTC)
I've tried to find the wiring diagram for your dryer and I could not.
It is very hard to diagnose the problem without the wiring diagram, but the first thing I would check is the thermal fuse and the hi limit thermostat.
Check them for continuity and replace if any one is open.
When you buy the thermal fuse, it comes as a kit, consists the thermal fuse and the hi limit thermostat.
The thermal fuse kit
UserPostedImage
- The part number for the thermal fuse kit AP415996
P.S. If you have the wiring diagram and can post it, it may help.
GeorgiaV
#8 Posted : Wednesday, November 28, 2007 6:05:51 PM(UTC)
GeorgiaV
I do have the wiring diagram and will scan and post in the morning. Thank you.
