Walt Lamb
#1 Posted : Thursday, April 2, 2009 10:29:06 AM(UTC)
Walt Lamb
Problem: Won't heat - all other elements work. Problem caused by using microwave without anything in the oven. Tried to use as timer but failed to cut on timer mode . After a few minutes fan cut on. After that no heat.
My guess is magnetron but would like to see if there may be a fuse. All lights and turntable motor works ok. My warranty says that there is a 5 year against manufacturer workmanship or materials. I don't think I fall into that catagory.
#2 Posted : Thursday, April 2, 2009 6:44:45 PM(UTC)
There are no such fuses in your microwave. Very likely the problem is a bad magnetron and if the microwave is less than 5 years old then it should be under the limited warranty (part only).
Here are the break down diagrams and Replacement parts for MAYTAG MMV4205AAW | AppliancePartsPros.com
Amana microwave will not heat (Microwave Repair)
by ckiley 2/1/2013 11:51:23 AM(UTC)
Microwave will not heat (Microwave Repair)
by scottdugan 7/26/2012 7:29:30 AM(UTC)
by villano 1/18/2012 12:24:46 PM(UTC)
by macguy44 12/31/2011 7:10:24 PM(UTC)
by vknipp 1/29/2011 9:42:28 AM(UTC)
by Cleatus 12/20/2010 4:40:14 PM(UTC)
Microwave will not heat anything (Microwave Repair)
by Stevew1987 1/2/2010 6:44:11 AM(UTC)
over the range Microwave will not heat (Microwave Repair)
by pdeclerck 12/27/2009 4:07:14 PM(UTC)
PLEASE HELP! Microwave will not heat (Microwave Repair)
by tratra 12/2/2009 8:28:30 PM(UTC)
by Lou C 3/25/2009 1:57:18 PM(UTC)
by jrt1000 1/27/2009 7:34:52 PM(UTC)
Microwave Will Not Heat (Microwave Repair)
by ocstanley 12/28/2008 7:19:44 AM(UTC)
Microwave will not heat (all else is functional) (Microwave Repair)
by FLAD 12/15/2008 11:57:20 AM(UTC)
Microwave will not heat (all else is functional) (Washer Repair)
by FLAD 12/15/2008 10:38:17 AM(UTC)
Microwave will not heat and makes slight noise (Microwave Repair)
by vsmith 11/28/2008 4:09:36 PM(UTC)
