tyohe@yoheconsulting.com
#1 Posted : Wednesday, April 1, 2009 9:49:31 AM(UTC)
I purchased a replacement handle for the above microwave. Before I purchased it I called the 877 number and was assurred I would not have a problem installing it.
I now have the handle. The screws are installed from the back of the front door panel. HOW DO I DISASSEMBLE TO DOOR TO GET TO THE SCREWS????????
You should know that I called the 877 number again and they were NO help! This has been a very bad experience!
I really hope you can help. Otherwise, it is going to be returned.
Sincerely,
Thomas Yohe
TechnicianBrian
#2 Posted : Wednesday, April 1, 2009 6:19:11 PM(UTC)
TechnicianBrian
The door needs to be slip open so you can get to the screws. Use a putty knife inserted between the outer door panel, and the inner plastic frame. Gently pull the frame (chock cover) off as you work your way around the door. The screws should be behind the cover. If they are still hard to get to, use the same putty knife to remove the outer door panel from the door assembly. If you break a tab or two, don't worry, there are plenty of them to hold the door together. Replace the handle then snap it all back together.
#3 Posted : Thursday, April 2, 2009 7:33:21 AM(UTC)
I was able to get the door open and replace the handle. However, the screws supplied were too long so it was not possible to tighten the handle to the front of the door. I was able to find and use the screws previously used to hold the door.
Tom
TechnicianBrian
#4 Posted : Thursday, April 2, 2009 7:39:23 AM(UTC)
TechnicianBrian
Glad it worked out for you.
tbadgett
#5 Posted : Wednesday, April 8, 2009 7:36:50 AM(UTC)
tbadgett
open the door and you will see a 1 in or so insert around inside frame i took a skinny knife and inserted it in slit and started lifting outward, it comes off once i got it away i was able to get the screws out one on each top and bottom, now i have a problem trying to get second hidden screw out top and bottom.
GE Profile #PVM917DFBB microwave handle removal (Microwave Repair)
by trifive 10/26/2019 10:36:24 AM(UTC)
microwave handle repair (Microwave Repair)
by rthill01 1/28/2013 3:06:37 PM(UTC)
Replacing microwave handle (Microwave Repair)
by gregx5 5/25/2011 11:39:20 AM(UTC)
Microwave handle (Microwave Repair)
by mrorvis 2/23/2011 3:23:42 PM(UTC)
Microwave handle repair (Microwave Repair)
by rburton61 11/26/2010 9:59:01 AM(UTC)
microwave handle broke off (Microwave Repair)
by bigbro 12/9/2009 6:41:06 AM(UTC)
Installing Microwave handle (Microwave Repair)
by Buckey1 5/12/2009 4:17:22 PM(UTC)
by gdevas 4/29/2009 2:40:29 PM(UTC)
Kenmore microwave handle repair (Microwave Repair)
by ginasal 3/20/2009 7:23:07 PM(UTC)
Broken off GE Microwave Handle pn #AP3187809 (Microwave Repair)
by mrbotto 2/7/2009 2:37:37 PM(UTC)
Microwave Handle replacement (Microwave Repair)
by Yusuf 2/6/2009 1:55:27 PM(UTC)
Install GE Microwave handle (Microwave Repair)
by icandoitmyself454 2/5/2009 4:43:55 PM(UTC)
How to install new microwave handle (Microwave Repair)
by Chalcook 12/23/2008 3:33:31 PM(UTC)
GE Microwave Handle Replacement (Microwave Repair)
by Graham Brown 12/14/2008 9:32:23 AM(UTC)
replace microwave handle/latch (Microwave Repair)
by windt4pe@aol.com 11/18/2008 3:55:17 PM(UTC)
