2 Pages12>
victortawil
#1 Posted : Wednesday, April 1, 2009 8:45:23 AM(UTC)
victortawil
after a few second the microwave goes straight to coolling how do i repair
#2 Posted : Wednesday, April 1, 2009 11:58:36 AM(UTC)
Can you be more specific on the problem? What is the complete model number of the microwave?
victortawil
#3 Posted : Wednesday, April 1, 2009 1:06:37 PM(UTC)
victortawil
thermador mbes 30" stainless micro wave
when yo s et time for 60 seond
microwave start to operate,
after few second like 4 to five seconds
it goes straight to cooling mode and doesnt warm the food.
how do u suggest i repair
victortawil
#4 Posted : Wednesday, April 1, 2009 1:09:57 PM(UTC)
victortawil
when you press heat time 60 second
it will begin cycle anfter 5 second pass , it stops and then begins cooling cycle
#5 Posted : Wednesday, April 1, 2009 4:06:52 PM(UTC)
I would suspect the control board. For more accurate advice we need the complete model number of the microwave.
tjohnsonscout
#6 Posted : Monday, June 29, 2009 10:26:52 AM(UTC)
tjohnsonscout
Hi, I've been facing a similar issue with a Thermador Microwave. When you tell it to cook, it will for a moment before switching to "cooling mode."
The microwave's model number is 16-11-157.
Thanks!
#7 Posted : Monday, June 29, 2009 3:29:28 PM(UTC)
This is not a valid Thermador model number. Verify and repost it.
tjohnsonscout
#8 Posted : Monday, June 29, 2009 3:42:31 PM(UTC)
tjohnsonscout
Hmm, it notified it as the model number, but if that's not the case, perhaps it's one of the following numbers:
Type: S333
F00074U60AL
FCC ID: ACLAP4u01
Serial #: 6HN2140243
Thanks!
#9 Posted : Monday, June 29, 2009 7:37:06 PM(UTC)
If this is an oven/microwave combo then the model number most likely is on the oven door frame.
yimyammer
#10 Posted : Thursday, January 14, 2010 6:50:40 AM(UTC)
yimyammer
Was a solution for this problem ever determined?
I have the same Microwave and model number and would like to know if there is any way to fix it.
I looked on the inside of the door frame and the model number listed is definately #15-11-157
2 Pages12>
