after a few second the microwave goes straight to coolling how do i repair
Can you be more specific on the problem? What is the complete model number of the microwave?
thermador mbes 30" stainless micro wave
when yo s et time for 60 seond microwave start to operate, after few second like 4 to five seconds it goes straight to cooling mode and doesnt warm the food.
how do u suggest i repair
when you press heat time 60 second it will begin cycle anfter 5 second pass , it stops and then begins cooling cycle
I would suspect the control board. For more accurate advice we need the complete model number of the microwave.
Hi, I've been facing a similar issue with a Thermador Microwave. When you tell it to cook, it will for a moment before switching to "cooling mode."
The microwave's model number is 16-11-157.
Thanks!
Quote:The microwave's model number is 16-11-157. This is not a valid Thermador model number. Verify and repost it. Gene.
Hmm, it notified it as the model number, but if that's not the case, perhaps it's one of the following numbers:
Type: S333 F00074U60AL
FCC ID: ACLAP4u01 Serial #: 6HN2140243
Thanks!
If this is an oven/microwave combo then the model number most likely is on the oven door frame.
Was a solution for this problem ever determined?
I have the same Microwave and model number and would like to know if there is any way to fix it.
I looked on the inside of the door frame and the model number listed is definately #15-11-157
