jstan
#1 Posted : Thursday, March 26, 2009 6:19:53 AM(UTC)
jstan
My side-by-side Conquest whirpool fridge is not making ice. The problem happened once when it was a little over a year old. Just happened again. The water that comes out of the black rubber tube that dispenses into the icemaker is frozen. Can I fix this easily at home and how?
woodchuckie
#2 Posted : Thursday, March 26, 2009 8:50:50 AM(UTC)
woodchuckie
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Whirpool ice maker dripping water into ice (Refrigerator & Freezer Repair)
by biddergirl 3/9/2017 7:40:44 AM(UTC)
Whirpool Ice Maker Corroding Black debris in ice (Refrigerator & Freezer Repair)
by tomkarl 11/19/2012 1:39:26 PM(UTC)
Whirpool Ice Maker not cycling water (Refrigerator & Freezer Repair)
by gator1996 3/2/2012 4:45:11 PM(UTC)
Whirpool ice maker not getting water (Refrigerator & Freezer Repair)
by bjustice 5/6/2009 9:13:54 AM(UTC)
whirpool ice maker (Refrigerator & Freezer Repair)
by srod407 11/19/2008 6:29:25 PM(UTC)
