Raymond S
#1 Posted : Thursday, August 4, 2011 8:35:52 AM(UTC)
Raymond S
Dryer would not start until drum rotated by hand. Replaced motor, dryer was used for 3 loads and now will not start. Could I have a bad motor? How do I check the motor? I have checked the door switch with a meter and it operates fine. When I press the start button you can hear the timer in the dial/selector but nothing else happens.
Jeff / APP Team
#2 Posted : Thursday, August 4, 2011 10:42:37 AM(UTC)
Jeff / APP Team
Hello Raymond. Test the thermal fuse and see if it is bad. It should read closed for continuity. If it is open, replace the fuse and check the vent for clogs or kinks. If it is good, make sure the motor does not have any loose wires or connections. Hope this helps.
Part number: AP4037790
electric dryer does not start (Microwave Repair)
by RayU 12/12/2013 7:03:52 PM(UTC)
Dryer does not start (Dryer Repair)
by Kalalau 9/20/2012 12:20:37 PM(UTC)
by hibidwns 6/25/2012 1:44:16 PM(UTC)
by Bharat 1/7/2012 4:02:37 PM(UTC)
Dryer does not start, can hear motor attempting to (Dryer Repair)
by bog 11/5/2011 9:52:03 AM(UTC)
by cpboudreaux 2/15/2011 8:59:37 AM(UTC)
Dryer does not start - Amana Gas (Dryer Repair)
by timjgtr 1/8/2011 10:10:33 AM(UTC)
Dryer does not start at all (Dryer Repair)
by timjgtr 12/26/2010 2:40:08 PM(UTC)
Gae Dryer Does Not Start (Dryer Repair)
by B Wall 9/10/2010 7:03:40 AM(UTC)
by D_Druz 3/1/2010 4:41:38 PM(UTC)
Dryer does not start, makes no sound (Dryer Repair)
by Pennell 11/12/2009 5:17:16 PM(UTC)
dryer does not start (Dryer Repair)
by petecardenas 10/19/2009 8:17:02 AM(UTC)
by petecardenas 10/19/2009 8:15:29 AM(UTC)
by bellaboo 10/1/2009 1:16:49 PM(UTC)
Amana dryer does not start (Dryer Repair)
by Barjensen 8/5/2009 4:21:07 PM(UTC)
