Dryer won't stop keeps running. Auto dry does not advance. Timed dry advances to cooling keeps running.
Does it start as soon as you close the door? If it does, then the problem is a bad start switch. Disconnect the vent hose on the back of the dryer and run a load on auto dry. Post your findings, please. - The part number for the start switch AP2997390 Gene.
No I have to push the start button for it to start any additional help
After disconnecting vent hose continues to run does not stop.
Sounds like the timer is bad. - The part number for the timer AP3097576 Gene.
Thanks for the information I will order the part and try to locate the old part on the dryer. Any idea where I might locate the part on the dryer.
Connie
The timer is located on the control panel.
I've replced timer and the timer know wont move and timer wont stop any ideas?
cseda
What is the model number of your dryer and what exactly is wrong?
Post it as a new thread, please.
Is this a electric dryer,if so make sure you have 240 at the back of the dryer. A blown fuse or breaker will cause the dryer to run continuous.
