2 Pages12>
caligal64
#1 Posted : Sunday, November 18, 2007 11:51:11 AM(UTC)
caligal64
Dryer won't stop keeps running. Auto dry does not advance. Timed dry advances to cooling keeps running.
#2 Posted : Monday, November 19, 2007 11:29:34 AM(UTC)
Does it start as soon as you close the door?
If it does, then the problem is a bad start switch.
Disconnect the vent hose on the back of the dryer and run a load on auto dry.
Post your findings, please.
- The part number for the start switch AP2997390
caligal64
#3 Posted : Tuesday, November 20, 2007 6:03:41 AM(UTC)
caligal64
No I have to push the start button for it to start any additional help
caligal64
#4 Posted : Wednesday, November 28, 2007 1:54:50 PM(UTC)
caligal64
After disconnecting vent hose continues to run does not stop.
#5 Posted : Wednesday, November 28, 2007 5:06:43 PM(UTC)
Sounds like the timer is bad.
- The part number for the timer AP3097576
caligal64
#6 Posted : Thursday, November 29, 2007 5:44:04 AM(UTC)
caligal64
Thanks for the information I will order the part and try to locate the old part on the dryer. Any idea where I might locate the part on the dryer.
Connie
#7 Posted : Thursday, November 29, 2007 10:25:35 AM(UTC)
The timer is located on the control panel.
cseda
#8 Posted : Friday, December 7, 2007 7:41:12 AM(UTC)
cseda
I've replced timer and the timer know wont move and timer wont stop any ideas?
#9 Posted : Friday, December 7, 2007 9:01:06 AM(UTC)
cseda
What is the model number of your dryer and what exactly is wrong?
Post it as a new thread, please.
abbie
#10 Posted : Friday, December 7, 2007 10:31:17 AM(UTC)
abbie
Is this a electric dryer,if so make sure you have 240 at the back of the dryer. A blown fuse or breaker will cause the dryer to run continuous.
Maytag dryer won't stop on timed dry (Dryer Repair)
by eaglemtn 11/11/2021 5:35:16 PM(UTC)
LG dryer won't stop tumbling (Dryer Repair)
by Danimal111 3/2/2018 9:53:47 AM(UTC)
Samsung Dryer won't stop running (Dryer Repair)
by Newbomb_Turk 12/6/2016 7:41:11 AM(UTC)
LP dryer won't stop running (Dryer Repair)
by rreyn 2/11/2015 2:53:15 PM(UTC)
Whirlpool Dryer won't stop running (Dryer Repair)
by Dave1234567 10/19/2014 5:45:40 AM(UTC)
Dryer won't stop running with heat-potential fire hazard (Dryer Repair)
by snowbound9 2/19/2014 5:37:54 AM(UTC)
Dryer won't stop spinning (Dryer Repair)
by Ddau 12/8/2013 6:15:22 PM(UTC)
Dryer won't stop (Dryer Repair)
by brendangall 4/8/2013 7:36:24 PM(UTC)
dryer won't stop after cylces (Dryer Repair)
by isabelg 3/13/2012 8:58:26 AM(UTC)
Roper dryer won't stop on auto sense dry. (Dryer Repair)
by outbackblackjack 2/11/2012 12:56:06 PM(UTC)
by outbackblackjack 2/11/2012 11:14:53 AM(UTC)
Dryer won't stop heating! (Dryer Repair)
by geotreker1 6/6/2011 3:32:10 PM(UTC)
Dryer won't stop buzzing or shut off (Dryer Repair)
by talbany1 5/19/2011 7:08:01 AM(UTC)
Dryer won't stop and no heat (Dryer Repair)
by krazykarl05 2/3/2011 8:42:17 AM(UTC)
by nrowe46 12/4/2010 10:41:00 AM(UTC)
2 Pages12>
