2 Pages12>
fgumin
#1 Posted : Tuesday, July 19, 2011 10:32:50 AM(UTC)
fgumin
I have a freezer top/fridge bottom. All of a sudden it stopped cooling. The motor is running and the freezer fan on top works , but there is no cold air coming out into the freezer. The condenser fan to the fridge runs for about 30 seconds then stops. Any advice how i can solve this?
richappy
#2 Posted : Tuesday, July 19, 2011 2:43:38 PM(UTC)
richappy
Your comments make little sense, try to organize them.
fgumin
#3 Posted : Tuesday, July 19, 2011 8:53:38 PM(UTC)
fgumin
Huh?
the condenser fan doesnt run. But It has been tested and is ok.
richappy
#4 Posted : Wednesday, July 20, 2011 1:08:38 AM(UTC)
richappy
Plug 115 volts into the condensing fan motor AP2071789, if it fails to run, order a new one.
fgumin
#5 Posted : Wednesday, July 20, 2011 2:29:22 PM(UTC)
fgumin
does that mean plugging it in to the wall? is that 115 volts?
richappy
#6 Posted : Wednesday, July 20, 2011 2:30:52 PM(UTC)
richappy
Yes, is stamped on the coil.
fgumin
#7 Posted : Wednesday, July 20, 2011 10:31:47 PM(UTC)
fgumin
ok. i did that and it works. when i put it back in the fridge it spins for about 15 seconds then stops.
richappy
#8 Posted : Thursday, July 21, 2011 12:42:36 AM(UTC)
richappy
If it will start when you hand turn it, you have a bad motor, or very low voltage to it.
fgumin
#9 Posted : Thursday, July 21, 2011 7:55:31 AM(UTC)
fgumin
Maybe I am not making my self clear. The Fan Motor works if I plug it in to the wall. My neighbor has the same fridge and it works. i pulled the condenser fan from his and put it in my fridge. It also spinned for 15 seconds and stopped. The problem isnt with the fan motor. I was hoping you could tell me where the problem lies. Thermostat? Defroster? I dont know.
richappy
#10 Posted : Thursday, July 21, 2011 8:09:17 AM(UTC)
richappy
You have a simple control in this, usually if the condensing motor goes off, the freezer fan motor and the compressor will shut down also, is this true?
2 Pages12>
