I have a freezer top/fridge bottom. All of a sudden it stopped cooling. The motor is running and the freezer fan on top works , but there is no cold air coming out into the freezer. The condenser fan to the fridge runs for about 30 seconds then stops. Any advice how i can solve this?
Your comments make little sense, try to organize them.
Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Your comments make little sense, try to organize them. Huh? the condenser fan doesnt run. But It has been tested and is ok.
Plug 115 volts into the condensing fan motor AP2071789, if it fails to run, order a new one.
does that mean plugging it in to the wall? is that 115 volts?
Yes, is stamped on the coil.
ok. i did that and it works. when i put it back in the fridge it spins for about 15 seconds then stops.
If it will start when you hand turn it, you have a bad motor, or very low voltage to it.
Maybe I am not making my self clear. The Fan Motor works if I plug it in to the wall. My neighbor has the same fridge and it works. i pulled the condenser fan from his and put it in my fridge. It also spinned for 15 seconds and stopped. The problem isnt with the fan motor. I was hoping you could tell me where the problem lies. Thermostat? Defroster? I dont know.
You have a simple control in this, usually if the condensing motor goes off, the freezer fan motor and the compressor will shut down also, is this true?
