Hello, I have aproblem with food freezing in the main compartment and top produce drawer in our Maytag MZD2768GE.
Measure the freezer temperature and post. Should be below zero if fridg running all the time. Critical to get a reading after the temperature has stabilized.
Hello, the temperature in the freezer compartment shows to be 10 degrees below zero. What should I check next? Thanks,
You probably have a bad cold control AP4070269
Where would I find the cold control and how to check it? Thanks
Behind the control panel where the temperature control knob is. Make sure to route the new sensing wire exactly where the old one was. Symptoms show a bad control. Try spraying with a non-residue contact cleaner available at Radio Shack, might un-stick it.
Hello, I changed temperature control which fixed freezing problem in main refrigerator compartment.The top produce drawer will change from a setting above freezing to 25 degrees and freezes food. Any suggestions as to what I need to replace to fix this problem? Thanks John
