My washer started leaking water on the floor. After I took it outside and examined it, I found that the tube that goes from the water level switch to the wash tub had come off on the wash tub. Would that squirt water out and cause the leak???
YES!!!!! Repair the tube and you should be all set!!!!!
Thanks.
So with the tube off, am I to assume that the watyer would just keep filling the tub and not stop. Overflowing the top???
