timmytes
#1 Posted : Thursday, March 5, 2009 8:51:17 AM(UTC)
timmytes
My washer started leaking water on the floor. After I took it outside and examined it, I found that the tube that goes from the water level switch to the wash tub had come off on the wash tub. Would that squirt water out and cause the leak???
Drags1998
#2 Posted : Thursday, March 5, 2009 11:32:53 AM(UTC)
Drags1998
YES!!!!! Repair the tube and you should be all set!!!!!
timmytes
#3 Posted : Thursday, March 5, 2009 11:36:17 AM(UTC)
timmytes
Thanks.
So with the tube off, am I to assume that the watyer would just keep filling the tub and not stop. Overflowing the top???
Drags1998
#4 Posted : Thursday, March 5, 2009 12:16:18 PM(UTC)
Drags1998
That is correct!!!!!!:)
Water level switch and something else maybe? (Washer Repair)
by tomsteve 2/19/2015 1:11:10 PM(UTC)
Washer overflows - water level switch replaced - did not help (Washer Repair)
by qeisus64 12/12/2014 2:15:59 PM(UTC)
Water still not stopping after water level switch replaced (Washer Repair)
by LIsa60 5/19/2014 5:33:24 AM(UTC)
GE Washer won't stop filling even after replacing Water Level Switch (Washer Repair)
by ctvquach 1/12/2014 4:33:29 PM(UTC)
Rinse - low water level - 2 Water Level Switches... (Washer Repair)
by Aleste 1/25/2013 4:20:37 AM(UTC)
Replacing water level switch (Washer Repair)
by Socalguy84 11/21/2012 8:07:56 AM(UTC)
by dellmack 8/28/2012 7:19:10 PM(UTC)
Two water level switches bad in 12 months? (Washer Repair)
by jfwilliams3 7/26/2011 8:35:32 PM(UTC)
installing water level switch (Washer Repair)
by chrisjay 3/4/2011 5:55:11 AM(UTC)
by bigdanallan 1/20/2011 7:42:20 PM(UTC)
Whirlpool Calypso Water Level Switch (Washer Repair)
by diyhelp 12/20/2010 6:14:21 AM(UTC)
by bowerman 11/2/2010 6:19:03 PM(UTC)
washer---water level switch (Washer Repair)
by brian_b@mail.com 10/26/2010 12:22:27 PM(UTC)
repairing a water level switch (Washer Repair)
by repairman756 1/10/2010 11:53:05 AM(UTC)
how do you test water level switch (Washer Repair)
by ldutton 10/11/2009 7:04:15 PM(UTC)
