dee1
#1 Posted : Wednesday, February 25, 2009 5:58:34 PM(UTC)
dee1
hi
I have a fridgidaire over the range microwave, all functions of the unit function, with the exception of the turn table does anyone have any idea how i can fix it or if it is repairable :confused:
TechnicianBrian
#2 Posted : Wednesday, February 25, 2009 6:16:30 PM(UTC)
TechnicianBrian
Remove the three screws along the front that hold the bottom plate (the part where the filters and lights are located) to the oven and allow it to hinge down, but hold on to it so you don't pull out any wires. The turntable motor (AP3770128) is in the middle and should have a couple wires going to it. Us a multimeter to verify voltage (120vac) to the motor when a cycle is started. If you have voltage and the motor doesn't operate, then it is bad. If you have no voltage, then there is probably a broken or loose wire.
Reduced heat from over the range microwave (Microwave Repair)
by natarajnv 7/27/2013 12:49:52 PM(UTC)
Installing new over the range microwave (Microwave Repair)
by pdl2 3/18/2013 3:06:13 PM(UTC)
GE Spacemaker XL Over the Range Microwave Oven (Microwave Repair)
by pxian 10/1/2012 2:19:42 PM(UTC)
over the range Microwave/convection (Microwave Repair)
by draft 7/31/2012 5:56:56 PM(UTC)
GE Over the Range Microwave Turns On By Itself! (Microwave Repair)
by LaneFowler 2/25/2012 11:19:51 AM(UTC)
Over the range microwave venting (Microwave Repair)
by johnjeanriv 10/15/2011 8:13:41 PM(UTC)
GE Profile over the range microwave oven (Microwave Repair)
by sadhuta 4/7/2011 10:02:31 AM(UTC)
by sadhuta 4/6/2011 2:04:38 PM(UTC)
GE Over The Range Microwave (Microwave Repair)
by mfortune 2/15/2011 12:08:14 PM(UTC)
Keypad on Ge over the range microwave (Microwave Repair)
by jgrant29 6/24/2010 10:22:49 AM(UTC)
over the range Microwave will not heat (Microwave Repair)
by pdeclerck 12/27/2009 4:07:14 PM(UTC)
Frigidiare over the range microwave (Microwave Repair)
by vickyh 12/5/2009 8:12:06 AM(UTC)
Ewave over the range microwave shutting off (Microwave Repair)
by chris112 4/28/2009 4:23:43 PM(UTC)
Over the Range Microwave blew a fuze...Complicated (Microwave Repair)
by abayomi 1/24/2009 2:15:51 PM(UTC)
GE Profile Over the Range Microwave Bulb Replacment (Microwave Repair)
by RLandis 11/20/2008 4:44:17 PM(UTC)
