ganderso
#1 Posted : Wednesday, November 7, 2007 12:18:26 PM(UTC)
ganderso
I have a Canadian-made KitchenAid range. The Model number differs slightly from the U.S. version, i.e., mine is YKERC507EW3. I believe the corresponding U.S. version is KERC507WH3.
The touchpad is erratic. Sometimes when inputting in the Timer function, the display will instead show up in the Temp. control, i.e., if setting 5:00 minutes in Timer mode, instead the display will show 500 degrees oven temp. has been set. The oven will then heat to 500 degrees, and the intended 5:00 minute timer does not register. Also, the oven heat seems to be innaccurate, sometimes spontaneously going into Broil mode.
I suspect the Oven control, Whirlpool Part AP2995057 should be replaced.
I understand you don't ship to Canada, but I have a U.S. shipping destination.
Please advise if the above named part is likely to fix the problem, and if I am correct in assuming compatibility between the Canadian and U.S. Model numbers given.
Thanks a lot.
Gerry
Calgary, AB
#2 Posted : Wednesday, November 7, 2007 2:03:32 PM(UTC)
Hi Gerry
Yes, you were right. Most likely the problem is a bad control and replacing it should solve the problem.
GE Oven Control board locking after starting oven. Model # CGS985SETASS (Oven Repair (including Ranges and Cooktops))
by Mike I 1/15/2024 10:55:45 PM(UTC)
Jenn air double wall oven control panel problems (Oven Repair (including Ranges and Cooktops))
by Guest 2/2/2023 3:45:53 AM(UTC)
GE Gas Oven Control panel blank (Oven Repair (including Ranges and Cooktops))
by sjohnson1161 3/17/2021 6:23:41 PM(UTC)
GE Electric double oven control panel part number (Oven Repair (including Ranges and Cooktops))
by Steveg297 6/20/2020 6:48:16 AM(UTC)
GE range JB645DK4BB, oven controls do not work (Oven Repair (including Ranges and Cooktops))
by jpmriley 2/24/2020 8:45:36 AM(UTC)
My double oven control board headaches (Oven Repair (including Ranges and Cooktops))
by Gunner41 12/9/2019 7:16:45 AM(UTC)
Oven Controls of Kitchenaid (Oven Repair (including Ranges and Cooktops))
by dballard1956 11/20/2018 4:14:02 PM(UTC)
How to remove Superba Oven Control Panel (Oven Repair (including Ranges and Cooktops))
by gofastr 4/5/2018 7:20:54 PM(UTC)
Stovetop is working, but the oven and oven controls are not (Oven Repair (including Ranges and Cooktops))
by EgorFed 1/7/2018 4:33:15 PM(UTC)
Replaced Oven Control Board- Controls still dont work (Oven Repair (including Ranges and Cooktops))
by chuckwagon00 12/10/2017 3:48:56 PM(UTC)
GE Oven Control Board (Oven Repair (including Ranges and Cooktops))
by BillDiesel 12/5/2017 7:36:41 AM(UTC)
Oven control board? (Oven Repair (including Ranges and Cooktops))
by denverdave 4/21/2017 8:44:54 AM(UTC)
Ikea Whirlpool IBS550PWW00 In wall oven Control Thermal Fuse?? (Oven Repair (including Ranges and Cooktops))
by teamlouish 3/29/2017 3:54:29 PM(UTC)
Clock & Oven controls not working (Oven Repair (including Ranges and Cooktops))
by wfcoleman 1/2/2017 2:51:37 PM(UTC)
oven control panel not working (Oven Repair (including Ranges and Cooktops))
by nocookintoday 1/26/2016 8:04:15 PM(UTC)
