nocookintoday
#1 Posted : Tuesday, January 26, 2016 8:04:15 PM(UTC)
nocookintoday
I have a Maytag performa flat top stove with a control panel (digital)and it is not functioning at all. All four burners are still functioning. What could be the problem?
#2 Posted : Wednesday, January 27, 2016 3:07:00 AM(UTC)
A model number would be helpful.
Find your model number - AppliancePartsPros.com
No the stove top indicator lights work?
Does the oven light work?
If not then you may have a power problem.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the wall receptacle
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
If the lights work then odds are that the control board/timer is toast.
PLES389ECE Oven control panel not working (Oven Repair (including Ranges and Cooktops))
by tfmc369 10/26/2014 8:34:27 AM(UTC)
New oven control panel not working (Oven Repair (including Ranges and Cooktops))
by MarshalW 2/13/2013 9:05:14 AM(UTC)
Kenmore oven control panel not working -no "F" code (Oven Repair (including Ranges and Cooktops))
by DisneyMommy 10/19/2011 8:22:19 AM(UTC)
