leper66
#1 Posted : Monday, November 5, 2007 6:37:57 PM(UTC)
leper66
hey guy's,have a frigidaire washer model #FWS833AS1,prob. 2 years old. just last night the wife was doing laundry when it got to the rinse cycle it just stopped,wouldn't fill with rinse water or nothing.will continue the spin cycle when manually done. the machine has 3 wash cycle's delicate.. etc,none of the rinse cycles will work.any idea's???much thx for any suggestions, leper66!!
okbobcats
#2 Posted : Monday, November 12, 2007 2:27:00 AM(UTC)
okbobcats
could be your cold water valve. make sure water is turn on or the hose is not kink. one way to check it is to ohm out the coil on the water valve. or get a old cord and put a couple of wire connector on end of cord hook to your cold water valve and plug cord in. if you get water in washer water valve is good. then maybe your pump is plug and not getting all the water out in the first place.
Cafe fridge keeps warming up. Help! (Refrigerator & Freezer Repair)
by Guest 6/28/2024 8:33:23 PM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
Help! Washer chirping noise (Washer Repair)
by Guest 10/8/2023 6:40:46 AM(UTC)
Troubleshooting Help!! (Dishwasher Repair)
by Guest 6/20/2023 1:14:28 PM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
Maytag Dryer MGD7230HW2 LP CONVERSION HELP!! (Dryer Repair)
by prodigey 10/14/2022 3:54:00 AM(UTC)
KitchenAid Artisan unknown problem. Please help! (Blender Repair)
by fakupos 5/17/2022 8:00:10 AM(UTC)
Mah2400aww Maytag Door Boot Door Diaphragm Discontinued, Help! (Washer Repair)
by DIY_Vee 3/4/2022 7:34:13 AM(UTC)
Ice maker dispenser will not stop running - help! (Refrigerator & Freezer Repair)
by Guest 1/30/2022 7:11:17 PM(UTC)
Maytag Bravos MCT HELP!!!!! (Washer Repair)
by Guest 10/23/2021 7:31:14 AM(UTC)
Help! Does motor need to be replaced or cleaned out? (Dishwasher Repair)
by connellh 4/30/2021 8:36:32 AM(UTC)
Kenmore not cooling - Can't get a replacement fridge HELP! :) (Refrigerator & Freezer Repair)
by shorton 11/9/2020 11:33:04 AM(UTC)
Help! GE Profile Electric Oven PT916SMSS (Oven Repair (including Ranges and Cooktops))
by Marsa 5/9/2020 8:36:48 AM(UTC)
HELP! Need clip or nut for Foot on Frigidaire Gas Range (Oven Repair (including Ranges and Cooktops))
by RichardKY 5/5/2020 6:43:52 AM(UTC)
