luiV
#1 Posted : Wednesday, May 25, 2011 5:24:12 AM(UTC)
luiV
Have a Kitchen Aid KSRG25FKWH03 refrigerator/freezer. The ice maker has stopped working. I have removed the unit and replaced. I have checked the LED light operation on the door. Seems the ice maker itself might be bad. Although unit is on, it does not have water in it at this point. Any suggestions?
Joe / APP Team
#2 Posted : Wednesday, May 25, 2011 6:58:52 AM(UTC)
Joe / APP Team
Lui,
You could still have a bad I/R sensor system, but try this first,
** you'll need a 2 or 3 inch length of wire with the insulation stripped off both ends **
Turn the power off the the refrigerator, or disconnect the dispenser harness at the freezer door top hinge.
Tape the freezer door switch and the I/R flapper down, (so the control thinks the door is closed).
Remove the front cover panel from the ice maker and find the openings labeled "T" and "H" in the front of the module panel under the cover( usually in the right hand corner of the module) Re apply power to the fridge and insert the 2 bare ends of the wire in the openings and hold it there until the large front gear starts to rotate, then remove the wire and the icemaker should advance through a complete cycle in a couple of minutes, if the I/R sensor system is OK.
Let us know what happens, so we can assist you further.
Ice Maker Problems - Whirlpool (Refrigerator & Freezer Repair)
by tomkarl419 4/27/2022 5:37:11 AM(UTC)
Whirlpool Ice maker problems - no ice (Refrigerator & Freezer Repair)
by mphillips9im 7/17/2021 11:48:06 AM(UTC)
Whirlpool In Door Ice maker Problems (Dishwasher Repair)
by mphillips9im 7/17/2021 8:10:42 AM(UTC)
GE Ice Maker Problems (Refrigerator & Freezer Repair)
by GM1123 8/16/2015 6:55:23 PM(UTC)
GE Arctica Side-by-Side Ice Maker Problems (Refrigerator & Freezer Repair)
by coondog 7/22/2013 2:56:20 PM(UTC)
by K7527 6/11/2013 8:51:25 AM(UTC)
by ejg593 5/13/2013 10:23:12 AM(UTC)
I bet you get tired of seeing threads titled "Ice maker problems" (Refrigerator & Freezer Repair)
by highdensity10 1/22/2013 8:35:52 PM(UTC)
Ice maker problems (Refrigerator & Freezer Repair)
by vernjust 10/3/2012 6:19:32 AM(UTC)
by nanette4060 5/22/2012 5:43:52 PM(UTC)
Samsung Ice Maker problems (Refrigerator & Freezer Repair)
by bjc7 8/27/2011 6:15:48 AM(UTC)
by emenemenem 6/21/2011 11:53:28 PM(UTC)
Ice Maker problems again after replacing parts (Refrigerator & Freezer Repair)
by hooliek 6/3/2011 3:10:03 PM(UTC)
ice maker problems-help (Refrigerator & Freezer Repair)
by gramm 11/24/2010 9:32:45 PM(UTC)
ice maker problems (Refrigerator & Freezer Repair)
by pollyboone@roadrunner.com 7/20/2010 10:54:31 AM(UTC)
