Joined: 7/17/2021(UTC) Posts: 0  Location: North Carolina
Whirlpool side by side refrigerator . Model WRS571CIHZOO with Ice maker in door.
I thought this would be simple but I am getting stumped.
No ice. No water in ice maker.
I checked the water filter - and went ahead and installed a new one - no help ( yes - I bled the air out ) Water pressure seems to be very good. I took the main line off and ran it in a bucket and it was strong. Good pressure at the water dispenser.
Switch is turned on and ice maker "full arm" is OK. Switch is OK at the dispenser container.
I went ahead and bought a new ice maker and installed it. No help.
I have a portable pyrometer and the freezer temp is good at zero.
I checked the water inlet valves with a meter and they all check the same ohms. I put the solenoid connector from the water dispenser on the ice maker water inlet valve and pressed the water dispenser paddle - and water went into the ice maker. This tell me its not the solenoid valve or a frozen line.
I spent a good hour looking for broken wires at the bottom of the door after seeng this problem posted with this model. I cannot find any broken wires,
I checked continuity from the plugs under the refrigerator to the ice maker and they all had continuity.
I inspected the main control board. everything looks OK. I removed all the connectors and put them back on - no help.
Does anyone have any other ideas before I buy a new control board? Any help would be appreciated. I do not know how to check for fault codes on this refrigerator.
