The Washer Doesnt Spin On The Final Cycle.
Originally Posted by: mikeyp31 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The Washer Doesnt Spin On The Final Cycle. MikeyP, Do you know if the washer motor runs, hums, or is there a clacking noise. The first thing to check is, the lid switch, raise and close the lid several times, and listen for the switch to "click" everytime,if the switch is bad , the washer won't spin, but, will fill and wash. If the motor runs and has a clcking noise, you'd have a broken drive coupling Part number: AP3963893
If the motor runs and there are no abnormal noises, you'd most likely have a bad clutch assembly or transmission Part number: AP3094537
