Does anyone know how to replace the door handle on a Samsung microwave? It is a stainless steel post joined by two plastic caps at each end. The caps seem to be held from inside the door and I can't get inside the doot to replace the plastic caps.
We have the same problem. Did you ever find out how to fix it? Thanks. :confused:
Look inside the door and there is a plastic insert around the glass. Take a flathead screwdriver and remove the entire rectangular liner. You can replace the caps and put the ring back on.
