I need help replacing door handle. I ordered handle and two screws. But can't find ways to get access to handle screws inside the door to replace broken handle. I looked up you tube videos and similar problem solutions posted on this forum, but they belong to different models and have easier way to get door frame out just using table knife. There are 3 screws on side and after removing them, it seemed that inside black assembly would hinge out easily and get me access to handle screws. However removing the 3 screws doesn't seems to have freed any parts! Please help if anyone has idea how to replace door handle for this specific model.
Originally Posted by: Atul I need help replacing door handle. I ordered handle and two screws. But can't find ways to get access to handle screws inside the door to replace broken handle. I looked up you tube videos and similar problem solutions posted on this forum, but they belong to different models and have easier way to get door frame out just using table knife. There are 3 screws on side and after removing them, it seemed that inside black assembly would hinge out easily and get me access to handle screws. However removing the 3 screws doesn't seems to have freed any parts! Please help if anyone has idea how to replace door handle for this specific model. I HAVE THE SAME PROBLEM. DO YOU SOLVE IT? COULD YOU HELP ME? THANKS
