segriggs
#1 Posted : Monday, March 21, 2011 10:45:58 AM(UTC)
segriggs
I've checked the float microswitch and its ok.
No voltage at the water inlet solenoid.
No schematic so I don't know where the red/white wire on the water inlet solenoid originates.
#2 Posted : Monday, March 21, 2011 12:45:05 PM(UTC)
Cannot find any info on the given model number.
I can tell you that the voltage originates at the timer.
Also it runs through the over fill switch, usually on the left hand side at the front of the unit. Perhaps the float is stuck in the up position or the switch is not closed for some other reason.
segriggs
#3 Posted : Monday, March 21, 2011 2:33:17 PM(UTC)
segriggs
MR. Denman,
I was afraid the timer would be your answer but thanks. I'd already taken out the float microswitch and determined it was working properly. Tomorrow I'll take the timer apart and see if the burned contacts can be located.
GE Dishwasher won't fill after grease (Dishwasher Repair)
by Guest 1/1/2022 3:18:27 PM(UTC)
Maytag dishwasher won't fill (Dishwasher Repair)
by dkirchner2@wi.rr.com 11/5/2014 5:40:40 AM(UTC)
Dishwasher won't fill or run (Dishwasher Repair)
by kevin.atkinson 11/28/2013 4:56:56 PM(UTC)
Dishwasher won't fill (Dishwasher Repair)
by mattgumaer 9/18/2013 7:02:29 PM(UTC)
Dishwasher Won't Fill (Dishwasher Repair)
by Rjkaster 1/12/2013 9:48:06 AM(UTC)
by SpedG 4/4/2012 8:23:34 AM(UTC)
Dishwasher won't fill, hasn't been used for months (Dishwasher Repair)
by talentetta 1/15/2012 10:49:50 AM(UTC)
GE Dishwasher won't fill (Dishwasher Repair)
by brotherleeroy 12/21/2011 9:53:36 AM(UTC)
Bosch dishwasher won't fill (Dishwasher Repair)
by sparky296 6/29/2011 1:17:33 PM(UTC)
Dishwasher Won't Fill -- Replaced Inlet Valve (Dishwasher Repair)
by wildwind 6/2/2011 12:23:53 PM(UTC)
Dishwasher won't fill and pump is loud (Dishwasher Repair)
by angelo c 3/7/2011 5:41:40 PM(UTC)
Dishwasher won't fill (Dryer Repair)
by idgie 1/24/2011 5:44:35 AM(UTC)
Maytag Dishwasher won't fill w/ water (Dishwasher Repair)
by boehlcj 1/12/2011 4:31:14 PM(UTC)
Kenmore Dishwasher won't fill up to wash. (Dishwasher Repair)
by Samuel Murphy 10/28/2010 8:04:26 PM(UTC)
My Ge dishwasher won't fill up all the way (Dishwasher Repair)
by taushabrady 10/2/2010 2:53:25 PM(UTC)
