SpedG
#1 Posted : Wednesday, April 4, 2012 8:23:34 AM(UTC)
SpedG
Dishwasher powers on and cycles, but no water enters the tub. Most likely a bad water inlet valve?
#2 Posted : Wednesday, April 4, 2012 12:43:12 PM(UTC)
Verify that the water supply is on and there is good water pressure to the water inlet valve.
Make sure the float (#15 at the diagram) is moving freely up & down and it is in down position.
If there is nothing wrong, check the float switch (#11) for continuity. The normal reading should be about 0 Ohms.
If there is nothing wrong, remove the wires from the water inlet valve solenoid and check for 120 VAC between these wires while the control calls for water.
If the reading is correct, replace the water inlet valve.
- The float switch Part number: AP2920872
GE Dishwasher won't fill after grease (Dishwasher Repair)
by Guest 1/1/2022 3:18:27 PM(UTC)
Maytag dishwasher won't fill (Dishwasher Repair)
by dkirchner2@wi.rr.com 11/5/2014 5:40:40 AM(UTC)
Dishwasher won't fill or run (Dishwasher Repair)
by kevin.atkinson 11/28/2013 4:56:56 PM(UTC)
Dishwasher won't fill (Dishwasher Repair)
by mattgumaer 9/18/2013 7:02:29 PM(UTC)
Dishwasher Won't Fill (Dishwasher Repair)
Belarus Rjkaster 1/12/2013 9:48:06 AM(UTC)
Dishwasher won't fill, hasn't been used for months (Dishwasher Repair)
by talentetta 1/15/2012 10:49:50 AM(UTC)
GE Dishwasher won't fill (Dishwasher Repair)
by brotherleeroy 12/21/2011 9:53:36 AM(UTC)
Bosch dishwasher won't fill (Dishwasher Repair)
by sparky296 6/29/2011 1:17:33 PM(UTC)
Dishwasher Won't Fill -- Replaced Inlet Valve (Dishwasher Repair)
by wildwind 6/2/2011 12:23:53 PM(UTC)
by segriggs 3/21/2011 10:45:58 AM(UTC)
Dishwasher won't fill and pump is loud (Dishwasher Repair)
by angelo c 3/7/2011 5:41:40 PM(UTC)
Dishwasher won't fill (Dryer Repair)
by idgie 1/24/2011 5:44:35 AM(UTC)
Maytag Dishwasher won't fill w/ water (Dishwasher Repair)
by boehlcj 1/12/2011 4:31:14 PM(UTC)
Kenmore Dishwasher won't fill up to wash. (Dishwasher Repair)
by Samuel Murphy 10/28/2010 8:04:26 PM(UTC)
My Ge dishwasher won't fill up all the way (Dishwasher Repair)
by taushabrady 10/2/2010 2:53:25 PM(UTC)
