tazzi
#1 Posted : Monday, March 14, 2011 12:56:47 PM(UTC)
tazzi
The dryer and blower are working but it's not producing hot air on any setting:confused: . Could this be a blown fuse? If so where might I find it's location? Thank you.
tazzi
sidfink43
#2 Posted : Wednesday, March 16, 2011 6:31:33 AM(UTC)
sidfink43
Well the first thing you want to check is that you have 120v coming to each side of the connection block. Sometimes one side can fail, which will allow your dryer part to run but not heat.
If that is ok, check the thermal/operating fuses that cut off power to the heating element when the dryer gets too hot. This service manual should help you find and test them.
https://secured.whirlpoo.../$FILE/L-56_4314124A.pdf
no hot air in dryer. (Dryer Repair)
by peavyxs 1/21/2015 7:54:50 AM(UTC)
No Hot Air (Dryer Repair)
by prometheus 10/27/2012 8:51:40 PM(UTC)
Amana NED7200TW No hot air (Dryer Repair)
by benfinkel 6/24/2012 7:12:57 PM(UTC)
