The dryer and blower are working but it's not producing hot air on any setting:confused: . Could this be a blown fuse? If so where might I find it's location? Thank you. tazzi
Well the first thing you want to check is that you have 120v coming to each side of the connection block. Sometimes one side can fail, which will allow your dryer part to run but not heat. If that is ok, check the thermal/operating fuses that cut off power to the heating element when the dryer gets too hot. This service manual should help you find and test them. https://secured.whirlpoo.../$FILE/L-56_4314124A.pdf
