lm144
#1 Posted : Wednesday, October 17, 2007 7:06:26 AM(UTC)
lm144
All Of A Sudden The Bake In The Oven Does Not Work, The Gas Ranges Work And The Broil Works. I Think It Could Be The Igniter In The Bottom Of The Stove For Bake Any Other Suggestions. Please Help
Pegi
#2 Posted : Wednesday, October 17, 2007 9:52:29 AM(UTC)
Pegi
Could be, check the amp draw if it is glowing to see if it matches the amps on the side of the gas valve, if it is not glowing need to see if it is broken or if there is no voltage to the igniter...
Kitchenaid oven baking element replacement (Oven Repair (including Ranges and Cooktops))
by Rocky D 1/19/2023 5:12:04 PM(UTC)
Frigidaire FES365ECA Stove baking elements will not turn on. (Oven Repair (including Ranges and Cooktops))
by Guest 1/10/2023 9:08:26 AM(UTC)
Inconsistent baking temperature (Oven Repair (including Ranges and Cooktops))
by Creativeguy 12/30/2022 1:42:38 PM(UTC)
Whirlpool slams door lock on/off during baking, then cooling (Oven Repair (including Ranges and Cooktops))
by 34Ford 9/29/2022 3:27:58 PM(UTC)
Amana gas range turns off while baking (Oven Repair (including Ranges and Cooktops))
by Shhomemom 10/18/2021 2:11:00 PM(UTC)
Kenmore 790.4678 Slide in Range. Baking element not working. (Oven Repair (including Ranges and Cooktops))
by zephlew 5/20/2019 5:21:30 PM(UTC)
Thermador baking element (Oven Repair (including Ranges and Cooktops))
by mianake 10/26/2018 9:02:47 PM(UTC)
by mpd038 3/15/2017 7:10:42 AM(UTC)
Whirlpool oven shuts off baking/broiling (Oven Repair (including Ranges and Cooktops))
by bremen242 2/13/2017 4:12:13 PM(UTC)
Downdraft fan comes on while baking (Oven Repair (including Ranges and Cooktops))
by Bob-J 11/17/2015 9:15:45 PM(UTC)
Baking element not working but broiler element is working (Oven Repair (including Ranges and Cooktops))
by majeromero 9/15/2015 7:41:26 PM(UTC)
baking element and broiler element not working (Oven Repair (including Ranges and Cooktops))
by davidmb 10/2/2014 6:54:11 AM(UTC)
Baking Element not working after replacing (Oven Repair (including Ranges and Cooktops))
by maxpower2078 8/19/2014 9:30:48 PM(UTC)
GE Oven - Oven doesn't get up to temp for baking but works for broil and clean (Oven Repair (including Ranges and Cooktops))
by emerscape 1/16/2014 6:47:51 PM(UTC)
Kenmore Elite baking element not heating (Oven Repair (including Ranges and Cooktops))
by candagrm 12/15/2013 9:29:47 AM(UTC)
