I have a Whirlpool OTR micorwave that is displaying a F6 error code. If I keep the door open then everything is quiet. When I close the door it buzzes like a stuck switch will not release. Any ideas? ![UserPostedImage](http://forum.appliancepartspros.com/images/icons/icon5.gif)
Originally Posted by: dbj ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a Whirlpool OTR micorwave that is displaying a F6 error code. If I keep the door open then everything is quiet. When I close the door it buzzes like a stuck switch will not release. Any ideas? ![UserPostedImage](http://forum.appliancepartspros.com/images/icons/icon5.gif) DB, The F6 code, indicates you've got a bad microwave relay, per the service manual. That relay is part of the control board / micro computer, behind the touch panel. Part number: AP3177273
This should help get you to the panel and control board, IMPORTANT: When you work on the microwaveoven, be careful when handling the sheet metal parts. Sharp edges may be present, and you can cut yourself if you are not careful. 1. Unplug microwave oven or disconnect power. 2. Remove the two screws from the top of the grille. 3. Pull the top of the air grille forward, lift the bottom tabs from the slots, and remove the grille. 4. Remove the screw from the top of the control panel. 5. Push the panel up to release the tabs from the slots. Pull the panel away from the microwave unit to gain access to the back side of it. 6. Disconnect the seven wire connectors from the control board. b) Remove 5 screws from the bottom board to release it from the touch panel assembly c) Press in on the locking tab end of the arm and lift the arm to release the touch panel ribbon cable. d) You can now remove the microcomputer board assembly. :) :) :)
