dbj
#1 Posted : Thursday, February 24, 2011 2:02:22 PM(UTC)
dbj
I have a Whirlpool OTR micorwave that is displaying a F6 error code. If I keep the door open then everything is quiet. When I close the door it buzzes like a stuck switch will not release. Any ideas?UserPostedImage
Joe / APP Team
#2 Posted : Friday, February 25, 2011 1:35:24 PM(UTC)
Joe / APP Team
DB,
The F6 code, indicates you've got a bad microwave relay, per the service manual.
That relay is part of the control board / micro computer, behind the touch panel.
Part number: AP3177273
This should help get you to the panel and control board,
IMPORTANT:
When you work on the microwave
oven, be careful when handling the sheet metal
parts. Sharp edges may be present, and you
can cut yourself if you are not careful.
1. Unplug microwave oven or disconnect power.
2. Remove the two screws from the top of the
grille.
3. Pull the top of the air grille forward, lift the bottom
tabs from the slots, and remove the grille.
4. Remove the screw from the top of the control
panel.
5. Push the panel up to release the tabs from the
slots. Pull the panel away from the microwave
unit to gain access to the back side of it.
6. Disconnect the seven wire connectors from the
control board.
b) Remove 5 screws from the bottom board to
release it from the touch panel assembly
c) Press in on the locking tab end of the arm
and lift the arm to release the touch panel ribbon
cable.
d) You can now remove the microcomputer
board assembly.
Whirlpool Duet F6 Error Code (Washer Repair)
by RookieBrian 2/13/2012 6:30:28 PM(UTC)
Kenmore Gas Range F3/F6 error codes (Oven Repair (including Ranges and Cooktops))
by ruju 4/25/2011 9:08:22 PM(UTC)
