I have a Maytag stakable washer, model LSG9900ABE. It won't agitate. Belt is worn, but it spins fine.Put pressure on motor to tighten belt but it actually almost stalled out during agitating cycle, so l don't believe it is the belt. Could it be the brake or is it the transmission? Any suggestions on how to check ,would be greatly appreciated. Than-you
Originally Posted by: 123laundry  It could be the transmission, also do you see any evidence of oil or water leaks from the bottom of the tub? There's a little bit of oil droplets on the bottom pulley l noticed, while checking belt. If l take transmission apart how hard to put back together? LOL Thanks 123laundry
Originally Posted by: 123laundry  Transmission takes time to replace not that hard though. Check transmsion relplacment videos on u tube that may help you. However parts are quite expensive thats why most people replace their machine when it gets to transmission problem. Okay thanks. I'm going to take apart just to see if l can see whats wrong. Let you know.
